Adjusting Lifter Pre-Load Question
I am searching for a definitive answer as to how many turns/flats I need to adjust the push rods to set the preload on my tappets. I am using the old-style Crane Time Savers that are 24 tpi. My lifters are Revtech. I see post that say anything from 2.4 turns to 3.6 turns. Thats a big difference. Can someone please tell me for sure where I need to set the pre-load? Right now, I have them adjusted 2 1/2 turns. Thanks!
24TPI pushrods travel .0417" per turn, so use that and, as has been suggested, set preload between .120"-140". I can't speak to the Rev Tech liters and their quality. Are you sure you adjusted with the lifters on the base circle of the cam? To be sure, set the piston at TDC on the compression stroke and adjust again.
Im not concerned with the noise. It sounds fine and the lifters are fine. I just want to adjust the proper pre-load. If .120" depth is where I need to be, thats what I'll go with. I just dont want to grenade the engine by incorrectly setting the pre-load. I would like to hear from mechanics that do this stuff every day. Thanks
Our methodology here is to load deeper, but as long as you have quiet operation let-r-rip.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
