Cam tensioners - I think they don't need replacing yet
Here are a couple of pix of the cam tensioners on my 2002 FLHTCUI with about 25,000 miles (bike was new to me last year).
There's some wear and one or two small pits.
I don't think they're in need of replacement. Opinions?
Inner cam tensioner
outer cam tensioner
Inner cam tensioner
outer cam tensioner
Based on your location I would think you can ride it this season and change them out next spring along with some new inner cam bearings. I have 33,000 on my 99 Road King and my tensioners were similar to yours maybe a little less wear. I replaced my cams so I changed the tensioners while I had it apart.
Based on the wear, the OPs tensioners are well within service limits. However, the problem with the early tensioner material, high and constant pressure from the springs and the exposure to heat and oil, the early tensioners, more often than not, could look like the OPs at 25K miles and fail catastrophically, without warning, at 26K miles. Replacing the OEM tensioners with the CYCO tensioners is cheap insurance against such a failure that can take out a motor that IMHO, why take a chance regardless of how good the tensioners look now when they could come apart down the road.............
true djl, but changing the tensioners isnt a matter of pulling them out and putting in new. It consist of removing cams. but even more replacing push rods or removing your rockers. Kind of a big project for tensioners that look like that. But yes i understand what your saying also. on the other hand, anything can fail at the drop of a hat. Thats my .02
It is actually not a big project to change the tensioners. There is a tool that is available to R/R the tensioners without removing cams. There is a forum member, NomadMax, that has one of these tools that are made by a machinist friend and the tools are for sale. I have suggested to Max that his friend consider renting the tool as well as selling but don't know if that decision was ever made. You can PM Nomad Max and inquire about the tool. A video illustrating the tool and how it works is attached via the below link.
https://www.youtube.com/watch?v=qoAI...ature=youtu.be
All you need is this tool, a set of the HD magnets that hold the lifters up so the cam plate/cams can be removed as an assembly. Pushrods do not have to be replaced nor do the rockers have to be removed. The rocker arm supports can be loosened up enough to move aside so the pushrods can clear and be pulled from the top.
If interested, find NomadMax on the members list and PM him about the availability of the tool, the price and the possibility of a rental..........
coma (05-16-2016)
...A video illustrating the tool and how it works is attached via the below link.
