Help !
Old May 26, 2016 | 11:43 PM
angelrod's Avatar
angelrod
Default Help !
I got 93,060 miles in my 07 EG UC . Runs like its was a few miles old . my engine is losing oil and hard to starts when it's hot , so I add a quart as the dip stick say so, then I notice after few miles running around I got an oil leaks in my primary then I decided to remove the derby cover to check if the oil is low , when I about to remove the last bolt it starts leaking oil .then I decided to just removed the drain plug .i got more than a quarts . I did check the engine oil and its low.what possibly wrong with my engine ? Oil seal or worst ?
Old May 27, 2016 | 07:19 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Crank seal.
Scott
Old May 27, 2016 | 10:39 PM
angelrod's Avatar
angelrod
Yup ! I got it out . Now I'm thinking to double the seal. The space were it was seated and the crank spacer has good amount of space to put a double seal .
Hardaker
Oil Archive (no new posts)
May 20, 2015 10:02 AM
Bassin
EVO
May 29, 2014 01:45 PM
2black1s
May 20, 2013 06:33 AM
brwdarr
EVO
23
Oct 15, 2009 12:03 AM
2Shakes
Exhaust System Topics
Apr 11, 2009 10:12 AM
