Andrews 57h in 107 or 110
I know almond with a 103 with those cam that is over 100hp.
dyno in a few months after break in
right in the middle of 107 with 57 cams stage 2 heads from hillside. cams and cam plate in oil pan off and totally flushed out, crank case vacuumed out . starting with a totally clean inside, figure for the 12 buck gasket and 3 hours of extra time may as well clean out any old oil and inspect what came out before I add all the new parts, polishing cylinder fins tonight , clean cylinders up and install pistons cylinders heads by the weekend, getting rocker lockers, noticed rocker pins starting to move in the cradles , then drive for a cpl months hope to get back to hillside by july for dyno.
Received 70,266 Likes
As was mentioned in the other thread where you posted this chart, SAE correction would probably put hp a bit below 100 hp, plus the possibility the dyno used could be a little happy.
