Scored Pinion Shaft & Bushing
Pulled my 06 TC88B cam chest apart for new cams, tensioners, etc.. 14k, stock motor; FP, exhaust and heavy breather. Lifters, cams, oil pump, all looked good.
There was a thin sliver of brass on the end of the pinion shaft, the pinion shaft is scored on one half only, along with the top of the bushing being scored. Crank run-out measured at the pinion shaft is .0035. Running my fingernail across the end of the crank, I can just barely feel the scoring.
What to do? I had planned to use a new '07 cam plate with hydro tensioners. Ream the bushing in the new cam plate? Polish the scoring out of the pinion? Seems to me, the problem is the bushing was not aligned or reamed properly, and crank run-out, while not real bad, is contributing to the issue. If it was just a run-out issue, I think the whole bushing would be scored, not just the top half. Conversely, if it was just a misaligned bushing, the pinion would show scoring all the way around.
Besides having the crank trued, any thoughts?
Thanks
Thanks
Scoring, in the world of machinery is never a good thing, as it will only get worse over time and sooner or later it will lead to another failure of some sort. Will it last for a while? Sure it will. So get it re-machined/re-built correctly and start fresh. It'll keep you on the road and not on the side of it somewhere.
The cam plate marks the shaft where the runout on the crank is most positive. It's not a bushing alignment / cam plate issue.. If it were out of line the crank pinion would have a mark all the way around. The cam plates are typically set up with 0.002 clearance on the bushing. If the plate / bushing were dead center of the pinion, you'd have 0.001 clearance all the way around on a perfect crank. If the crank runout is more than 0.001, the pinion will touch the bearing and you'll see the rub marks.
Don't worry about it.. 0.0035 ain't that bad. Especially if staying with chains.
Going to talk to a local big twin machine shop, see if they have reccomendations on a fix, without dismembering the entire motor.
Thanks for all your input. I'll let you know what happens.
I saw your pics. How many miles on yours?
With a .012" runout, the bushing would have to be huge to accommodate runout like that. The shovels used to loose oil pressure when bushing got worn, wonder if same thing would happen with a TC.
Going to talk to a local big twin machine shop, see if they have recommendations on a fix, without dismembering the entire motor.
