View Poll Results: Which cam for low end torque?
Multiple Choice Poll. Voters: 132. You may not vote on this poll
Cam poll: best low to mid torque
Basically, that's what mine has already. Besides, you can only have a maximum of 10 choices on these polls.
JMHO but there are only four cams in the list that will set corrected compression/CCP at a manageable level and facilitate a good tune; Woods 555/777, TMan 555, SE259 and S&S 570. I would eliminate the SE cam because it is an SE cam; dealer's choice on the others. I am a TMan fan and would have to be looking at his 590 and 585.
Just spoke with Keith at Fuel Moto, great guy, he recommended the 222's if staying stock elsewhere. 555's for mild head work and triple 7's to future proof it. He said the 7's will feel about the same down low as my stock cams, but will come on stronger later in the rpm's. He also said the gasket wasn't really worth it.
Bafflingbs (03-31-2017)
I think there should have been two polls because you are talking about two different engine builds. There is a best cam for the just cam replacement and the head gasket and then there is a best cam for the increased 10.5:1 compression. I only have experience with Andrews but without the increased compression the 48 would be my pick, but after the increased compression I'm not sure which would be best. The Andrews 57 is good up to around 10.2:1 but 10.5:1 is something else.
Unless I go with Djl's recommendation for the T-man 590 (which sounds good, by the way)
