View Poll Results: Which cam for low end torque?
Multiple Choice Poll. Voters: 132. You may not vote on this poll
Cam poll: best low to mid torque
Some of those cams are best suited at stick compression, others at around 10-10.2, and others around 10.5.
i think you need to work out a budget and exactly what you want. That will enable you to narrow down what you do.
if you're doing the cam change yourself then it's a good mod. But if you're paying a shop to do it it's exxy and worth considering doing more to it.
based on just a cam change but forecasting port and polish headwork later I would consider the cr575 or the 57h
good luck
good luck
Bafflingbs (02-04-2018)
If I understand the new question, we are talking a cam only upgrade to an other wise bone stock 103" motor with an exhaust upgrade? In that case there are only two cams on the list that qualify iMHO; the 48 and the TTS 100. The SE255 is not on the list but should be, again, JMHO. I think you would be happy with either but the TTS 100 or the 150 would be my choice based on what I have seen performance wise with an emphasis on torque.
That is like "how long is a piece of string" ...different builds, different needs ...different cams. Like you said earlier ...what is he aiming for?
