Starting question, 10:1 compression
Things that will help.. One heat range cooler plug gapped at 0.032 will help as will backing off the timing. Lower idle. say 950.. No throttle on starts..
If you are using 36A on the Dynatek for the curve you probably have way too much timing. I would try 30B but once you correct that you might find throttle response a little lacking. The documentation is not very good on what the Dynatek module is doing during cranking..
That is the nice thing about the Dynatek 2000i You can select however many dead revs you need. I use 4. Not only that it also will not advance the timing curve till once the motor rpm's are over 500. And you can change all that as well... I believe the Software comes with the ignition but the patch cable is optional....
We'd have releases in that here.
All the 103's @ the stock 9.6 cr from HD are release equipped.
Can save a lot of headache.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
http://www.dynaonline.com/support/do...NA%202000%20HD
Nothing wrong with the 2000I.. I run one in an evo bobber.. Nice thing about evos is that you can you can twist the plate to retard the timing. The 2000i won't work on a Twincam.. The Dyna TC88-1 is real limited in what it can do..
