Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
2010 fxdb not starting. i was ran up onto a center median, bike did not go down. i shut the bike off and now it wont turn on. fuel pump does not prime, no power to front head light nor blinkers, no instrument panel lights unless you push in the function button, i can get the odometer light. rear lights do come on, also red key light flashes. all fuses are good. battery is good. could this have something to do with the bank angle sensor, even though i didnt lay the bike down? just picked up my voltmeter, have yet to check for broken wires. connectors all look good.
Fallow up:
Rear lights only come on when the key is turned to accessory. I've checked all connections and pins. Checked the relay, didn't click in. Going to replace that and see if that's it. Next step will be dropping the bike off at harley
