Clutch recommendations for a 124
I'm running a scorpion on a 131 ci bike (one in the avatar) that made 144/146 HP at one time. Have made some changes and don't really know what it makes now.. I am running the 3 of the 58 lb springs and 3 of the 82 lb springs.. It seem to be holding OK but the lever is a little stiff, currently running 18 degree ramps.. Friction zone is fine. Feels like stock.. No problems finding neutral. I will probably go to 21 degrees ramps and an easy boy to drop the lever pressure down some.. I'll be able to tell if the clutch is slipping when I dump the primary oil next oil change.. Can go 2/4 on the springs if needed.
Was running an SE clutch with Barnett +1 CF kit. Used 18 deg ramps and the easy-boy to get enough pressure to hold the motor but the lever pressure was pretty high. The clutch used STD width frictions which was part of the reason for needing high spring pressure..
Don't care for centrifugal lockup clutches on the mountain roads where curves are involved..
i have the scorpion on my S&S 124 (145tq/135hp) -- slightly stiff on the hand, holds well, needs to be warmed up - to alleviate the grabbing, I learned to use it and live with it -- I had the AIM VPC 92 on a 107 (122tq/111hp) - much easier to deal with much better feel, close to stock pull and holds exceptionally well.
Easy clutch lever pull, plenty of holding power.
Fat11Lo (05-21-2017)
Most of what I have heard is the Scorpion is harder on the hand
Bandit claims "• Lighter lever pull - greatly improved ‘feel’ and ease of operation"
http://www.banditmachineworks.com/pd...ndout203RN.pdf
I want a clutch I won't have to worry about or have to replace should my appetite for more power increase. I'm getting tired of buying stuff only to take it back off because it won't work with my next mod. My thinking is with this type of clutch all I would have to do is change up the springs if needed.
Higher rpms, it's harder pull as the lock up is fully engaged, but you aren't a street racer are you?
It's gonna be a long time till you have to worry about that package not handling the power your motor puts out.
For now it's great, but if you step up the HP a lot, or even now for insurance, get Barnetts billet basket. The newer bikes stock baskets are a crap shoot.
Fat11Lo (05-22-2017)
Bandit is top notch for the strip. With the added hat and it's full adjustability. The thing can really be tuned to what you want. BUT for a street ridden bike. It can be a bit grabby. Stack height and free play movement can be less forgiving. Running less fluid helps, but I don't know how the affects these late model comps. I have also seen them be very intolerant to a slipping clutch. Steel plates are thin and loose their temper pretty quick.
I like the feel of the over center on a diaphragm clutch. For street bikes I like the Primo Pro Clutch. Big builds that peak tq around 4500. Adding their hat is an option.
No, it isn't...not with your low profile lockup. I have tested it with way more HP than you have (although I have the older 6 finger LU, and not the new low profile), and it's easy on the wrist-for normal 2-4 grand shifts-all day.
Same unit that AIM has offered(and we have stocked) since the early 2000's.
Those, apparently, have green weights.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
lkr0 (06-04-2017)
