Clutch recommendations for a 124
Old 05-22-2017, 06:37 PM
PWMORRIS's Avatar
PWMORRIS
PWMORRIS is offline
Originally Posted by Fat11Lo
Is the bolt on basket OK (321-30-02012) or the one with the primary and ring gear (321-30-46012)?
As long as your current ring gear works, teeth aren't worn or damaged, and years match, use it, but call Barnett tech (not sales), and get everything perfect and matching with what you have.
It will be a killer set up for your motor package.
Fat11Lo (05-22-2017)
Old 05-22-2017, 06:52 PM
cdonis's Avatar
cdonis
cdonis is offline
Originally Posted by hrdtail78
Bandit is top notch for the strip. With the added hat and it's full adjustability. The thing can really be tuned to what you want. BUT for a street ridden bike. It can be a bit grabby. Stack height and free play movement can be less forgiving. Running less fluid helps, but I don't know how the affects these late model comps. I have also seen them be very intolerant to a slipping clutch. Steel plates are thin and loose their temper pretty quick.
I like the feel of the over center on a diaphragm clutch. For street bikes I like the Primo Pro Clutch. Big builds that peak tq around 4500. Adding their hat is an option.
My Indy wrote ( pro clutch ) on the parts list. I'm pretty sure this is the one he is talking about.
Old 05-24-2017, 06:32 PM
Fat11Lo's Avatar
Fat11Lo
Fat11Lo is offline
Billet basket is on the way
Any recommendations on what springs or combo of springs to start with?
I'm going to go ahead and apologize to cdonis for hijacking his thread, sorry man.
Old 05-31-2017, 10:37 PM
Bafflingbs's Avatar
Bafflingbs
Bafflingbs is offline
I just installed an AIM VP84LT today. Stock spring and plates. This thing is friggin awesome!!! I ended up getting a much lighter clutch pull, and lock up seems to be solid. I love it!
Old 05-31-2017, 10:44 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,245 Likes on 3,623 Posts
https://youtu.be/Qz--QRG9hzY
In a bike with a 124?
Old 05-31-2017, 11:14 PM
Bafflingbs's Avatar
Bafflingbs
No. I gave my recommendation for that. Bandit. But, the AIM product was mentioned several time, throughout this thread. I just thought I'd give my experience with AIM's little brother, the 84. Which is good for 130HP, with the stock spring and plates. It's big brother, the 95, is stronger, and will take 150. But, nice of you to fact check me...
Old 06-01-2017, 08:57 AM
Max Headflow
What do you mean "fact check"?
From what I've seen the 84 does better as you can still pull the clutch in at high Rs.
brad75raiders
Engine Mechanical Topics
05-07-2018 06:17 PM
800screws
EVO
11-01-2016 08:21 AM
Notgrownup
08-23-2014 08:14 PM
Big Twi$t
12-19-2013 12:12 PM
Fesnl
02-20-2013 03:51 PM
Quick Reply: Clutch recommendations for a 124
