Stage 4 103 with Andrews 57
I bought a 2012 Flhtk with a stage 4 103 running Se 259 cams. Runs great from 3500 plus. Was looking at Andrews 57 cam to possibly move the torque band to more in the cruising range. Or will the compression be too high for this cam. Do mostly 2 up riding. Or is there another cam that will work better? Thanks
curious to what you are thinking there (on account of I have said 57H) ...the IVC and EVO happen earlier than the 259 and the LSA are quite different as well...??
[QUOTE=mirrmu;16284819]57h would be step in wrong direction, cam spec very similar to the 259e
as much as the advertising by Andrews says 2200-5500rpm
keep in 4th or 5th[/QUOTE
I'm curious also... I was concerned that it would build too much compression down low. Looking at most dyno sheets the torque comes on way earlier, but none of the sheets on here are running 10.5-1 compression that I have seen.
Intake 18/38
Exhaust 46/14
I think you've swopped columns and rows there somewhere
(I think it's the SE585 that is quite similar to the 57H)
