96-crank 2007 what's the percentage
Old 06-16-2017, 12:36 PM
brad75raiders's Avatar
brad75raiders
brad75raiders is offline
Default 96-crank 2007 what's the percentage
I ride hard but don't do burn outs or wheelies I recently read an article saying the 06-07 twin cams had a rash of week cranks. I am putting together a mild 107 but don't want any drama. My Dyna is. A 2007 made Oct 2006. Anyone know what the chances or percent of these bikes have **** cranks? It has 211 cams now runs great but the 107. 57h might push the envelope.?
Old 06-16-2017, 12:44 PM
nevil's Avatar
nevil
nevil is offline
Don't know where you read that or what "expert" you're citing, but I've had my 07 for almost 10 years and haven't heard anything about that. If you don't thrash it too hard the odds are that it will not self destruct. If you want to be absolutely 100% sure about it get the crank trued and welded.
Old 06-16-2017, 01:06 PM
hog-doc's Avatar
hog-doc
hog-doc is offline
There were limited issues in 07, of all the bikes that ran through the shop in Colorado only mine and one other had a crank shift, if it hasnt happened yet...probably not going to!
That being said, nevils suggestion of sending it out to be trued and welded is worth the time and expense. Send it to Dark Horse!
Old 06-16-2017, 01:08 PM
brad75raiders
Good !!!
Old 06-18-2017, 12:59 PM
Lambda's Avatar
Lambda
Lambda is offline
07 here with FM 107, had a emerency stop (can't remember if I pulled the cluch, probably not, ended in the ground lol, **** stock brakes) runout stays at 0.004, 31000 miles, and I beat her sometimes but never done any wheelies or runouts, not my style.
Old 06-18-2017, 04:30 PM
brad75raiders
Ok good thank you I have 22k now.
Old 06-19-2017, 05:29 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
2004's were the absolute worst, and 2007's had their share, and that is a cold, hard, fact.
Check it at the install, and then again, say, in about 2500-3000 miles to witness any right-side flywheel half movement.
IF wanting to sleep real good, let Darkhorse go thru it, or at least pin/weld.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 06-19-2017, 06:04 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 6,319 Likes on 3,267 Posts
So I never asked, did Moco fix this problem? After 07-07
Old 06-19-2017, 06:22 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
no,havnt been "fixed" yet
Old 06-19-2017, 11:45 AM
brad75raiders
If the flywheel comes out it will turn into a 124'
Quick Reply: 96-crank 2007 what's the percentage
