Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm running the R&R Overflow with a SE 58mm. The only thing I don't like about it is the SE throttle body and intake manifold don't physically bolt together, and the Overflow only mounts to 1 head, so the whole thing seems a little unstable to me, although I'm sure it will be fine.
2 mounting brackets or 1, and Is your tb throttle by wire? Cable driven units should have 2 brackets according to r&r. Same part numbers but you need to specify if you have a cable driven tb, to get the extra bracket. Interesting, I remember reading your prior post on the r & r now.
Parts list- S&S hot set up a/640 cams
S&S tc3 oil pump and plate kit
SE 58mm with 5.3 injectors
Oil cooler kit
Primo Rivera pro clutch
I'll be reusing my D&D bobcat.
I've got a cable TB. I did specify that when I ordered, but I only got one bracket. I'm not sure a second bracket would fit, when I initially installed it on the front head, it didn't clear the throttle cables/cam, so I just put it on the rear head. I should see if they'll send me a second one, probably could make it work with the right placement of washers.
chris that R&R setup works great had it on two builds with no issues. use two hoses so your dragon can breath !!!
Thanks for the info target! So as of now I'm still undecided on a throttle body. I have 950 bucks in harley cash( se 58 ), and harley (oil cooler) that I've had for a year. Not sure yet so I'm waiting on a call back from Jimmie at hpi, also tossing the idea of an s&s throttle hog.
Add.. Does HPI or SnS make a TB for cable that big for a Breakout?
Hpi makes a 62 cable. And can't be sure if the 66 hog has a cable option now that I think of it.
Jimmy has done the flow testing. No numbers in my possession just trusting his info.
