Report Zippers Hydraulic Tensioners
I pulled the cam cover to check the outside zippers cam tensioner. This tensioner has about 45000 miles on it.. Running W777 cams and AVnV 185 lb springs.. Seems to be holding up well.. While I didn't check run-out this time, last time it was 0.003".
I've talked to both Dan Fitzmaurice and John Kitzmiller quite a bit about Tmax and other performance stuff but have no relationship with them. Zipper's stuff has always been top notch..
Good info.
We stock those here, and consult with our clients when we see the OE's worn.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
prodrag, I'm about to believe your right, I bet there is a REALLY low % of failure's that ate a motor in the real world, it's like Russian collusion-say it enough and most will believe it, theres alway's a bad 1 in any subject, most pic's I see are tensioner's in good shape (like mine @ 34K) there are a few BAD stories out there, but I agree the more homework I do on this, the more I think it's WAY overblown.
