Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
You sure or you just guessing? I had an intake leak an the head and my idle went high to around 1800. Caught it by pointing propane gas in that area and it coughed and stumbled.
Yes. It's lean if you have surging while cruising at partial throttle position/opening. Say around 1/8 to 1/4 turn at the grip. Possible the throttle position sensor is off but I would stick with some form of fuel enrichment first.
Thank you everyone for your help. Here is an update:
Today was really hot. The surging got worse. The engine died a few times when I let off the throttle. There was some surging during acceleration too now. The check engine light came on and went off a couple of times. I barely got back home.
