Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Agree on Ultima but not sure about ratio. Also noticed witness marks on the support bolts indicating the shaft is rotating in the support boss and making noise. Rocker Lockers would solve that problem.
