Alternative to the Andrews 57H
The 57 is a high lift version of the famous 37, with tweaked exhaust timing.
It loves 10.2 cr.
Even without compression being fully optimized, it should still work pretty dang good.
Scott
It loves 10.2 cr.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I think I need to side with some of the others here. It's not the cams, but the tuning giving you grief. I installed the 57H's this winter. Started with the PV and a tune from FM, Ran ok. Tried autotune sessions and got worse in the low end. Eventually went back to FP3, and bike actually ran better. Then emailed Dynojet and was given a tune. That really didn't run well. Went back to FM's map, and a couple more autotunes. Bike was running better. Finally had it dyno tuned. Night and day difference. Runs so much smoother, and stronger. If you have anyone over there than does dyno tuning, you need to give that a shot.
Well I wasn't going to dredge back through tuning on this thread ...I've had plenty of others where, with all of the help from you guys, I've probably been through more stuff than most are even aware of ...so I'm happy with tuning.
I'm good enough at collecting good enough data that my PV and FP3 actually come up with more or less the same answer. I've stepped through timing tables one degree at a time, same with AFR in closed-loop. Idle gain control, closed throttle spark, and I've even bypassed the MAP sensor because I thought that was where the instability was coming from. And yes, I've tried every combination of IVO/IVC
I think the consensus is saying something is fooked somewhere so I'm going to tear into it again n see what the heck I did
Maybe I was hoping someone was going to say I needed a 107/110 build to get a better all rounder, lol
Gimme some spanner time and I'll let you know what I find, and/or take it to DJ for one of their tunes
EDIT: Aogmitch, that kind of negates the idea that the 57 is supposed to be easy to tune, but sounds horribly familiar, and you're not the only one I've heard say that.
Originally Posted by Gordon61
tuned by pot-luck and crossed-fingers
oleboy (07-25-2017)
I've heard that higher MAP VEs typically need more fuel than the smoothed narrow band tuning suggests.
Check the compression, fuel pressure. If both are good , take it to a qualified tuning shop otherwise fix the issue.
Especially if you are trying to tune with narrow band sensors..
Mapping VE tables is one part of tuning. It is done with O2 sensors. Mapping AFR table is another part of tuning. This is done by power readings, time for distance or seat of pants. Meaning that you can use whatever sensor to map VE tables at one AFR target and then change that target to a richer mixture if needed. The flip side of this is tuning before closed loop. Might target 13.5 across the board to map VE's, but that didn't mean the whole table stayed at 13.5.
Max Headflow (07-24-2017)
Bike was running the best I had gotten it since cam install, before the dyno tune. Base line to finished product had gained about 5 hp and 5 ft/lbs for most of the rpm range. All the tunes I tried after cam install were running very rich, which showed in my mpg's. Prior to cams, I was averaging about 42-43. After cams was getting 30-32. After the dyno tune, I'm back in the 40's again. Also, throttle is very crisp and responsive now.
mirrmu (07-25-2017)
He has been trying to manually tune it himself (without a dyno).
