Sea foam top engine cleaner
02 flhtcui with 103000 miles on the stage one (powervision) 88. I put a camera in the cylinders and found a fair bit of carbon build up. I wanted to try out the sea foam through the intake trick,but the can warns to spray it downstream of maf sensors. Safe to assume that it'll foul my map sensor as well?What have others done?
Or you can use the vacuum port on the TB.
There is a thread on here with detailed info.
A member really went the Xtra mile to clean up carbon build up.
Do a search on Google for carbon build up and put HD forums after it.
Maybe that because it's not a carb cleaner.. It's not bad for carbonizing the combustion chamber.. For carbs, use Berryman's Chemtool or even straight lacquer thinner will work.. If the jets are plugged, a soak in carb cleaner is about the best..
We carry Seafoam in the retail area.
It does a good job of removing carbon from the chamber, and pistons.
When cleaning a carb, NAPA has a kit with a dip basket, and a 1 gallon(?) container.
Soak a carb/parts for 24 hrs.........super-clean.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
