Where to from an 88?
So far I'm getting a lot of 98" recommendations so I'll stick to that as far as that goes. Cam recommendations have been all over the place. Headwork, if I'm not getting too crazy is it worth the extra time and $ or will I not gain enough to justify headwork with just a mid range cam and 98" displacement?
If you're only doing the cam, stock will work.
Either way, you'll be pleased.
I beg to differ with S&S,(great folks over there, btw) but you will not like that 585 in a touring bike, as low-mid torque is paramount.
A .570 at 10.0 cr would be better, but not anything like Andrews 21, if going step, by step.
If going to a 98" initially, an Andrews 26 would be our choice.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I've been calling around and getting quotes, suggestions, and tips from various places including some of the sponsors here. Lots and lots of info. Good news, options are plentiful! Bad news, everyone has something different to offer/suggest.
Ugh
Not blowing off those on here I have been in contact with via email I want to throw two setup options out there for your thoughts.
1- Fuel Moto 98" Big Bore kit. This kit comes with all required components to upgrade to chain driven cams with the hydraulic tensioners. Woods 555 cams made for this conversion kit, as well as the cylinders and pistons of course. They also offer headwork. Their cylinders are OE bored out or I can upgrade to ones that are reinforced with a liner of some sort. They have a core system where I can send them my parts AFTER I receive theirs so downtimes are limited to the install. They also offer their Jackpot 2 into 1 exhaust as a package deal with a powervision which is attractive.
Problem is I'd have to twist someone's arm to get them to install parts I bring to them.
2-a local Indy wants to set me up with a Feuling kit. Hydro tensioners and fueling plate and pump. Reaper 543 cams. Feuling lifters. A 98" kit. Stock pushrods. D&D exhaust and a thundermax tuner. This Indy is also going to set me up with powder coating so I can black out my chrome and having this done at the same time makes this attractive. Out the door All for slightly under twice the cost in just parts for option 1.
Option 1 I'd have to install myself to justify the benefit in price difference but that's a wholenother bag o worms.
Any thoughts?
Ugh
Any thoughts?
If going with a 98" out of the gate, vs, a step by step approach, then an Andrews 26, set at 9.65 cr.
HUGE power increase, right where a heavier touring bike can use it.
Scott
