Street Bob 96” with TW-777 cams
A bit of clutch slippage at 3000rpm
Just got the bike back today. Had some Woods TW-777 cams installed, decked heads .030, cleanup of port, and an evolution industries 30T compensator sprocket. Ended up with 95hp and 105tq. Pulls very hard once you get up to 3000rpm. Also, the increase in rpm from the sprocket makes it a bit smoother cruising at 60-70. In 6th at 60 the bike pulls to 80 faster than it used to in 4th.
I'm gonna make an educated guess from the provided info from the manufacturer of the sprocket.
3250RPM / 70MPH * 80MPH =~ 3715RPM
Here's the specs from Evolution Industries, should give you somewhat of an idea. (my bike doesn't have a tach unfortunately)
Raises RPM to achieve maximum performance eliminating lugging of motor.
Changes stock 1.352 gear ratio to 1.5333 gear ratio.
- 4th gear 70 MPH @ 3620 RPM to New 4th gear 70 MPH @ 4500 RPMs.
- 5th gear 70 MPH @ 3042 RPM to New 5th gear 70 MPH @ about 3750 RPMs.
- 6th gear 70 MPH @ 2570 RPM to New 6th gear 70 MPH @ about 3250 RPMs.
Nice increase over stock.
Now a 107" set at 10.4 cr, and headworK.......
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Bike now has a 107", Headwork, 50mm ported throttle body, 999-6 cam, set at 11.3cr.
Numbers are 116hp and 121tq.
Was hoping for more with that high of a compression ratio...
Pipe is a D&D Fatcat and I'm not sure what gear the pull was done in.
I wasn't sure if the 30T Comp Sprocket had an effect or not...
