Atf in primary
Old 10-08-2017, 11:06 AM
Clayton24's Avatar
Clayton24
Clayton24 is offline
Default Atf in primary
Anyone use atf in the primary someone suggested it to me an was jus lookin for opinions ? Thanks
Old 10-08-2017, 11:09 AM
TriGeezer's Avatar
TriGeezer
TriGeezer is offline
Received 29,273 Likes on 11,143 Posts
HD Formula+....
Yeah...some people use ATF, and will swear by it, but why when HD F+ works perfect.
Old 10-08-2017, 11:17 AM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,628 Likes on 1,176 Posts
I have long been using Mobil 1 syn ATF with 4 ounces of Lubeguard highly friction modified ATF supplement. Smoother quieter shifts, and no more KLANK that wakes the neighbors on cold starts. I highly recommend it.
NOTE: Not all ATFs are the same, some don't work well at all. Use the exact combo I mention above & you'll be happy.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 10-08-2017, 12:07 PM
Sc0-'s Avatar
Sc0-
Sc0- is offline
With the Alto Carbonite clutches it requires ATF...
Old 10-08-2017, 02:38 PM
rhuff's Avatar
rhuff
rhuff is offline
Received 1,118 Likes on 732 Posts
I spoke with Alto. While they suggest ATF, they said Formula + or belray gear saver would work just fine
Old 10-08-2017, 03:09 PM
hrdtail78's Avatar
hrdtail78
hrdtail78 is offline
Straight ATF has no lube properties. I’d suggest an ATF w/ a lube additive like mentioned above.
Old 10-08-2017, 09:58 PM
propflux01's Avatar
propflux01
propflux01 is offline
If straight ATF had no lube properties, there would sure be a lot of automatics locking up over the years.
The Mobil one is my choice as well.
Old 10-09-2017, 05:28 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Atf has been used in the chaincase area in HD's since back in the early 80's(and perhaps earlier) when forks would block off the oiler, and have that running in it's own oil.
Many automotive manual gearboxes use atf these days, and have many clients that subscribe to it also.
We do, however, use Red Line MTL(called V-Twin Primary now) in the chaincase, on builds and services here.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 10-09-2017, 07:45 AM
Clayton24's Avatar
Clayton24
Scott
. Thanks for the info i can relate to the automotive manual transmissions using atf as i run an automotive service garage an some do call for atf thanks ! I'll check in to the redline .
Old 10-09-2017, 03:08 PM
Sponsor
You can get the Mobil 1 syn ATF and the Lubeguard at the local Autozone.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sporsters
Quick Reply: Atf in primary
