Help adjustable pr with 570 easy start
yea, I got it finally,lol..what it is, was I heard 5 different ways of doing it, I narrowed it down to the most logical, that I understood, rode all day, no tapping, ran nice!!!today was a good day, thanks
I'm no expert, but how I do it is have a buddy turn the rear wheel while I have my fingers on the lifters (watch them in your case since pushrods are already in) the whole purpose in TDC compression stroke is so the lifters are on the base circle of the cam. Once I get both on base circle (rear cylinder) I set the intake at zero lash then do however many turns out those pushrods require. Then I set the exhaust the same way. Let it sit for an hour or so. Now have the buddy roll the rear wheel and watch for both lifters on the front cylinder to be on their base circle. Now adjust the front cylinder just like you did the rear. Also note that this is for regular cams. I've never used easy starts so not sure what variation comes with them.
I have the SE 50mm throttle body, I just changed my AC to an HPI and it's a work of beauty.
My exhaust is made by Supertrapp, great unit tuneable for volume and performance. Fuel Moto makes a nice exhaust similar in technology as well.
thanks brotha, now I have to learn to how to use this power vision, I thought it would be easy like fp3 YEAAA RIGHTTTT, I don't even know if I programmed it, I couldn't find a success screen, or anything saying eco took tune, when I shut , doesn't matter ill call fuel Moto on Monday,lol, one problem at a time, man upgrading a motor , didn't realize all the work id encounter, especially all the money I have into this now, I should be just riding?????
I looked, I don't see where after you shut key off to lock in program, any type of sucsesss screen etc, as if I loaded tune they sent, bike stalls immediately? I didn't think it would be that off
