S&S bolt in 110 build
Old 09-15-2017, 08:44 PM
Mntl1's Avatar
Mntl1
Mntl1 is offline
6th Gear
Default S&S bolt in 110 build
Hi Guys new to this forum and thought i would share the specs of the 110 i am currently getting built for my 2016 breakout.
factory heads cnc ported and set up for cam
S&S 110 Bolt in cylinders and piston kit
S&S 635HO gear drive easy start cams
10.3:1 comp ccp194
S&S pushrods
feuling lifters oil pump and camplate
HPI 55-58mm Throttle body
Figure Machine Vision 5 air cleaner
S.E Variable pressure clutch
will be dyno tuned with a power vision and hoping for 130hp/tq
I currently have bassani pro-street exhaust but will be looking at changing that out for either a bobcat or burns stainless no holds barred exhaust.
Old 09-15-2017, 11:21 PM
cdonis's Avatar
cdonis
cdonis is offline
Bobcat will work just fine.
Old 09-15-2017, 11:34 PM
Mntl1's Avatar
Mntl1
Mntl1 is offline
6th Gear
thanks for reply have not been able to find many people that have used the bobcat exhaust everyone seems to go for the boarzilla unfortunately they dont have one for the breakout how do these exhaust perform do they produce good torque off the bottom i am hoping i could produce 110ft lbs by 2500rpm with my set up
Old 09-16-2017, 12:01 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,810 Likes on 1,063 Posts
Really no need for the Easy Start cams as the stock heads and the stock ECU have the provisions for compression releases already installed.
Old 09-16-2017, 12:09 AM
cdonis's Avatar
cdonis
cdonis is offline
[QUOTE=Mntl1;16642059]thanks for reply have not been able to find many people that have used the bobcat exhaust everyone seems to go for the boarzilla unfortunately they dont have one for the breakout how do these exhaust perform do they produce good torque off the bottom i am hoping i could produce 110ft lbs by 2500rpm with my set up[/QUO. Works pretty good with my 124. As long as the parts work well together you should have a nice runner.
Old 09-16-2017, 01:06 AM
Mntl1's Avatar
Mntl1
Mntl1 is offline
6th Gear
yeah i know but my engine builder likes to use them because they crank over a bit easier with them
Old 09-16-2017, 01:08 AM
Mntl1's Avatar
Mntl1
Mntl1 is offline
6th Gear
[QUOTE=cdonis;16642108]
cheers mate i do like the look of the bobcat would have to be the best looking production 2-1 exhaust
Old 09-16-2017, 08:54 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,784 Likes on 3,300 Posts
10.3:1 comp ccp194
S&S pushrods
Figured Machine Vision 5 air cleaner
Good luck.....
Old 09-16-2017, 05:56 PM
Mntl1's Avatar
Mntl1
Mntl1 is offline
6th Gear
Good luck.....
do you think these numbers are not achievable with this setup
Old 09-16-2017, 06:27 PM
target64's Avatar
target64
target64 is offline
that's a load of BS running 220 psi staring with stock ACR with no problems!
OldEnuf2NoBtr (09-16-2017)
Quick Reply: S&S bolt in 110 build
