Tight valve train
Old Sep 19, 2017 | 07:33 PM
frostyblue714's Avatar
frostyblue714
1st Gear
Default Tight valve train
I have a 07 road king stock 96 with 46k on it. I got a 103 kit from my local Harley dealer. Jugs, pistons, cams and clutch spring plate. After assembly the valves chatted very loud. The cams are 255's so I got kibblewhite .600 springs. Now the engine is very tight. Do I need to get adjustable push rods, roller lifters? Anyone have any ideas?
Old Sep 19, 2017 | 07:43 PM
roussfam's Avatar
roussfam
Tight??
Old Sep 19, 2017 | 08:27 PM
baloot-boy's Avatar
baloot-boy
What do you mean by tight? Noisy valve train? Do you have the double wound KBs? Those with the 255s will be noisy. Might be able to quiet it down a little with adjustables and lifters set at about .140
Old Sep 19, 2017 | 09:07 PM
ROCKOUT Rocker Products
Sponsor
Did you start it up, hear the "chattering" & shut it down? If so that's your problem... you need to run it a few minutes to get oil into the lifters & the top end.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Sep 19, 2017 | 09:46 PM
ntraindavefl's Avatar
ntraindavefl
This OP makes no sense. Probably just an internet lonely guy looking for attention
Old Sep 19, 2017 | 09:55 PM
roussfam's Avatar
roussfam
I think he's legit...
Old Sep 20, 2017 | 09:41 AM
frostyblue714
1st Gear
Default Tight
I have the bee hive springs. I changed the stock springs with kibble white .600 lift ones. I haven't ran it now. It turns over really hard. I'm tearing it apart to check the clearance at the valves.
Old Sep 20, 2017 | 10:25 AM
lt1-xjs's Avatar
lt1-xjs
With stock heads and a .045 hg your corrected compression is around 9.5 pushing 200 ccp. You'll probably need compression releases. Run a compression test.
Old Sep 20, 2017 | 10:34 AM
Schex's Avatar
Schex
If the lifters are not pumped up, the intakes are closing early, making high cranking pressure.
Remove plugs, ground the plugs wires and spin it over a few times for 15 seconds, letting the starter rest in between.
With the 255's and 103", you may sometimes have hot start problems without compression releases
Old Sep 21, 2017 | 05:56 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I would suggest a set of adjustable pushrods, loading the lifters to .140".
Scott
