Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Engine Mechanical Topics (https://www.hdforums.com/forum/engine-mechanical-topics-46/)
-   -   kurykayn tc-2d cam's???? (https://www.hdforums.com/forum/engine-mechanical-topics/1205367-kurykayn-tc-2d-cams.html)
HD9358 Oct 28, 2017 12:51 PM
guy's,
I have an 07 lowrider basically stock with stage 1 upgrades.. SE air cleaner,rinehartstaggered dual's.. stage 1 download from dealer by previous owner.. been debating on cam upgrade to improve low and mid range response.. I know Andrew's 48 is top choice as I used them on my last ride.. story is I run across a screamin deal on a set of the kury tc-2d cam's???? hard to find much info and opinion's on these cam's.. would like some opinion's on how these cam's will perform.. plan on using a powervision if we do the install??? appreciate all in put..
thank's
Max Headflow Oct 28, 2017 01:04 PM
They are crap.. Can work reasonable if you bump the compression up to 11 to 1.
HD9358 Oct 29, 2017 03:20 PM
nobody has any first hand experience's with these cam's?????????????? some input would be appreciated!!!!!
Max Headflow Oct 29, 2017 06:36 PM
I've not tried the TC2s but have plenty of first hand experience with the TC26s.. Only difference is the lift.. You might some lovers over on HTT.
jbarr1 Oct 29, 2017 06:40 PM
Max gave you the answer. The specs favor MUCH more compression than stock. If you are looking to improve low to midrange power, these are definitely not the answer.
HD9358 Oct 29, 2017 07:11 PM
I do appreciate everyone's opinion...
Hillsidecycle.com Oct 31, 2017 04:40 AM
Your private message was sent minutes ago.
As Bruce has said, and my response as well......11.0 cr.
NOT a plug/play cam.
Scott
HD9358 Oct 31, 2017 05:58 PM
everyone I appreciate your responses and advice about these cam's.. guess I need to find a forum member that's building a motor that could use these cam's.... brand new in the box!!! will take pic's later this wk and post in classified section.. anybody interested 150 plus shipping..
thank you...........
Hillsidecycle.com Nov 1, 2017 09:31 AM
Same answers on HTT.
Scott
Fat11Lo Nov 1, 2017 09:46 AM
Scott
Saw that too........LOL
© 2026 MH Sub I, LLC dba Internet Brands
