Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I swapped to Woods 777's in my Stage 4. Here is Dyno.
What bike did you put the 777's in? Wolf has done work for me in the past and I like what he does. Been debating a stage 4 and having him install with a non HD cam.
It was in my 15 Twin Cam. He is going to tune my 18 RGS once it is broken in. The cam alone picked up 8 lb ft and 4 hp over previous cam and moved the torque curve to the left quite a bit. The 259E’s came on too late for me and I didn’t lose any too end HP either.
Looking at the chart. I dare say your problem is more in your tune. Would a new cam give more? Sure...
But honestly you haven't even reached the full potential of what you have yet.
You have alot of dips in the early stages of power.
This. Get a competent tune, then see if you still need a new cam. A well tuned stage 2 will outperform your bike from where you're sitting right now. The tune will be the best 3-500$ you ever spent.
