Compensator insepction
The S/E upgrade has a plastic windage tray to gather oil in motion and direct it at the comp sprocket, to aid in lubrication, and epoxy is used to adhere it to the outer cover.
On another note, solid sprockets are being used on a quite regular basis, to side-step the comp-sprocket issues altogether.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I changed mine out to a Baker last winter, but my sprocket looked MUCH worse than that. My sprocket had serious flats in it. Strange thing was I wasnt getting the typical bang on start up / shut down.
From what I see in your pictures most of the wear is off to one side. Wonder if thats the result of the autotensioner? I didnt have that issue in mine. Primary chain over tightened = shaft deflection / more wear on one side vs the other?
joebedford
Engine Mechanical Topics
59
11-06-2016 08:36 PM
slimvela
08-18-2013 06:36 PM
