Beating a dead horse 96-103
Old 11-13-2017, 04:46 PM
Lundee's Avatar
Lundee
Lundee is offline
Default Beating a dead horse 96-103
My 08' street glide is blowing smoke at 50k. I picked up a complete 100mile take off set of 103ho head, jugs, pistons, injectors, throttle body, lifters, pushrods, cam plate, oil pump, & cams.
I plan on all new gaskets, a quick hone and rings to be safe. This is on a budget so nothing crazy.
I'm assuming I should use all of the 103 stuff, including the injectors and throttle body?
However, is it worth it to pop a better set of cams in or are the 103ho's good enough? I mean more power is better, but I'm broke as a joke.
Anything else I should be looking at?
Thanks.
Old 11-13-2017, 07:16 PM
GroovusMagnus's Avatar
GroovusMagnus
GroovusMagnus is offline
There is nothing at all wrong with the stock cams. I enjoy the hell out of mine.
GM
Old 11-13-2017, 07:45 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,218 Likes on 3,603 Posts
With 100 miles, I wouldn't bother with replacing the ring or hone if you can match the pistons to the cylinders.
Add:
I'd use a 57 cam unless you are a low end torque freak then I'd go with the 48..
Old 11-13-2017, 08:33 PM
Lundee's Avatar
Lundee
Lundee is offline
Thanks gents. Undecided on cams as of now.
Would you suggest using every 103 component I have? Seems logical, all my parts have 50k on them.
Old 11-13-2017, 08:44 PM
Max Headflow
I don't have any problems with it.. The big cost will be the tune to match the selection..
Old 11-13-2017, 09:01 PM
FestusRocks2001's Avatar
FestusRocks2001
FestusRocks2001 is offline
If your bike is stock and if the upgrade is from a Rushmore. You will be real happy with the cheap upgrade. Get a buddy and pay a license fee To use his tuner. And I will be shot for this. But for now use a canned tune. He’s broke! Will run darn good. Later on change the cams and have it tuned.
Old 11-13-2017, 09:57 PM
Max Headflow
Good idea, if there is a stage 1 program available for the HO103. Not sure you can "licence fee" a copy of the tuner (HD). Even buying the tuner new might be OK tho you'd get stuck the EPA version. Finding a valid copy of the non neutered version would be good because you could get the bike tuned later if desired.
jbarr1 (11-14-2017)
Old 11-13-2017, 10:08 PM
GroovusMagnus
If he's swapping in 103 parts, the warranty is moot. Use a real tuner and ignore the EPA.
GM
Old 11-13-2017, 10:14 PM
Max Headflow
GM
I agree.. The problem is cost, maps available and bucks available. Might need a tune.
Old 11-14-2017, 09:45 AM
djl's Avatar
djl
djl is offline
Received 2,010 Likes on 1,489 Posts
Tuner in my area collects a license fee plus dyno time which can vary but is usually about 4 hours; total cost for fee and tune is about $450. You also get the tune on a flash drive so you are not locked in to his shop for future tunes.
Quick Reply: Beating a dead horse 96-103
