Fresh 107 on bench. Hissing out intake valves
So I recently had my crank done and got head work also. Did a 107 with Tman 625 cams. This thing is still on my work bench(everything new as far as I was told)After the fact this may have been a bad idea. But, I got out my fancy ratchet wrench and began slowly turning it over a couple times. I can hear blow by out the intake valves. Is this normal?? Or should I be calling the shop that put it together for me?
Thanks in advance
Thanks in advance
Perform a leakdown on it, as Kirby has already mentioned.
If the shop used conventional double-wound springs, the upper valve collar could be touching the lower rocker cover, holding the valve open.
Only a guess.
Seen that on OE S/E models on many occasions.
Did not cause any issues except unwanted noise.
Scott
Only a guess.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Whaaaaaaaaat????????? Really? Does that mean that dirty valves don't hiss? or at least not terribly? Two reputable Harley pros have suggested a leak down test; me thinks that is good advice.
Should not be any hiss... If you have roller rockers, rocker covers are likely holding the valves open and need clearancing.
I should qualify that,.. The intake can hiss a little when closing but not near TDC on the compression stroke..
