Twin Cam motor removal
There ain't any way I'm pulling pulling a motor out without a hoist... I put the bike on the side stand and use an engine hoist.. I don't use the strap method but slide a small wood scarp under the tranny at the motor mounts and let it rest on the frame.. No straps to mess with..
The wood block makes removing the pan difficult. Wood block on scissor jack for removing and installing engine. Strap holding it up for remove and install of pan. Also I like the strap in case I need to move the bike off the lift to make room for another one. Can’t always just let them sit while cranks or heads are out for work.
If you look at the pic.. You can see the wood block.. It's more like a stick.. You can pull the pan if desired..
The following 2 users liked this post by speedzter:
Max Headflow (11-21-2017),
Timothy Beighton (01-08-2021)
This is a little off topic, but can someone please explain the trans oil xfer? I gather it xfers to the primary? But how?
I'm not a W8 owner but was VERY impressed with the one I test rode. A buddy has one he rides the $hit out of (stone stock 107 RG) and so gar no issues.
I used to be a Mercedes Benz tech. Any time a new model came out, there were issues that had to be ironed out despite many hours of R&D and pre-produvtion testing. Doesn't make it any less frustrating to be one of the buyers with problems, but it's the nature of vehicle manufacturing....
