Compression ratios on a 110.
Hopefully this is a fairly simple question for the engine gurus here.
I have a twin cam 110 long block that was installed in my 2012 FLTRU in 2016. I therefore assume it is a 2016 engine. I have left it fairly stock, but it does have the SE110 heads, SE259e cams, SE 58mm throttle body, SE Heavy Breather, SEPST, and V&H Power Duals with V&H High Output slip ons.
I have been pretty happy with this combination as it currently dyno's at 113bhp and 123 Ft/lb of torque.
My main question is about the compression ratio. I have been told that this motor is 9.2:1 from the factory. That's fine. It works well. However, I have also been told that the SE259e cams prefer a bit of a compression boost to really perform well.
If I have stock 9.2:1 CR, what would I gain if I replaced the factory Head Gasket with something thinner, perhaps a 0.030" head gasket? Is it worth the effort? I would like to get closer to 10.0:1. Would I risk clearance issues with this cam and a thinner head gasket?
I still have another year on my ESP, so no work will be done before then. I'm just doing research at this point.
Any advice is greatly appreciated.
I suggest you do a compression test before anything else.. never assume what the comp is... Then plug the numbers into a dynamic compression calculator to figure your static comp. Then you'll have a base to figure the next step... Personally I don't believe your static is at 9.2:1. If it was I don't think you would be getting the numbers that you are..
The average amount of material removed from the head gasket surface to see 10.0 cr from those heads, using a .030", gasket is .030".
To arbitrarily cut them w/o cc'ing them is a dice roll, but on the average, what we've seen here, is .030".
Once at 10.0, the door opens up to several cams.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
speakerfritz
Engine Mechanical Topics
10-02-2011 07:14 AM
