Best Performance With 1250 Big Bore kit?
I’m sure his shop has pumped out lots of stroker rubbermount xl’s
splitting the cases on the rubber mount engines is a lot more difficult than it used to be as the trans does not come out a trapdoor anymore. when i went to the 2004 model year XL school at the motor company, we had to tear one down and put it back together again while being timed and observed and a basic function test.
that in its own right makes it harder but not impossible to do, and i dont think that i'd trust stock cases to something that wants to put out 120+hp and big torque especially and the center case connecting bolt area between the cylinders. like i said, not impossible, but i dont know many people that like Xl's as much as i do for as long as i have. mine is 100 hp and 105tq with a S&S 89 inch kit and too much more to list, but it is the love of my life!!!!
m
m
I have a 2008 1200c Sportster. I've been looking into getting a 1250 big Bore kit. I think I've ruled out getting an 88" or 90" because I want to as much of the work myself as I can.
I have already got my exhaust and intake picked out. If i could get some input into preferred brands for big bore kits and cams, and anything else anyone might recommend for for this project. thank you in advance for everyone's help.
I followed the above advice for my twin cam. I email and called several people about what I wanted to do and it has really help me to nail down who I would like to use. Several people sent email replies that were not even about my engine or I got no reply at all. The two vendors here were very helpful and didn’t mind talking and offering up advice. (Getting my funds in order know) I know the warm fuzzy won’t help your engine run better, but if I don’t feel I can trust you, you can keep your reputation and I can keep my money. I like to spend money with people that I feel good about.
I had him do the 1250 kit with cams and head work. It was a fine running machine and very fun to play around on. I believe they stay on the for front of sportster engine development. You can get a ton of info off there site that can help you pic out exhaust, carbs, cams and such. There is a lot of info on his customers on the xl forum. Shoot them a email or call and just talk with them about what you want. That should help you make up your mind about if they are a good fit for you.
Nope. You're the one who was being a snarky jackass. Go back and read your posts in the third person and you'll see what I mean. Scott is a good guy who knows what he's doing. And I'm not being sensitive. I'm just "calling it as I see it." Haha.
LOL 😂 And still waiting to hear about this 106” and 114” stroker in a rubbermount Street Bike. I didn’t say he wasn’t a good guy or that he doesn’t know what he’s doing, but suggesting these big cube strokers in a rubbermount frame is hilarious!!!!!
Happens, sometimes. Of course, I'm guessing you would never, ever make a mistake or overlook something? I'm done here.
“Is the 1250 worth the extra money?
A 1250 is about 4% more displacement than a 1200. Assuming displacement is limiting the power of the motor, 4% more displacement would yield 4% more power. In reality, it generally comes out a little more than that, on the order of 6-7%, because there's an increase in compression that comes with it when comparing to a stock 1200. Also, the larger bore unshrouds the valves a bit more and enhances breathing.
So is 6-7% more power worth the cost of the kit? On an otherwise stock 1200, probably not. You can find more power than that with simple pipe and air cleaner changes. But once you've picked all the low hanging fruit, you'll quickly find that additional horsepower starts getting very expensive. At that point, a 1250 kit will be the cheapest horsepower you can buy.
On an 883 that's being converted, though, the picture is quite a bit different. The incremental cost of the 1250 kit over a 1200 conversion kit is only a couple hundred dollars or less. That makes the decision quite a bit easier. Toss in the fact that Sledge Hammer cylinders and pistons are much higher quality pieces than the stock type conversion pieces and it becomes a no-brainer.”
FYI: It’s quoted because I didn’t write it, but I feel it’s great information about a 1250/1275 set up over a standard 1200
