Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Yes but maybe just running the proper size thread restorer, or dye, will "un bugger" the threads and removal is not necessary. If not, double nut the exposed threaded section and it should back right out. If you get some resistance, apply some penetrating oil and let it sit for a while before trying to back back it out. Use the same double nut technique to install the new studs.
Left handed drill bit, then used EZ out and slowly threaded stud back out... some serious luck 😬
That is one way to get it done. Some are stuck so tight, EZ Outs will break; sometimes being luck is better than being smart. Use some anti-sieze on the new stud.
master auto mechanic here. worked at ford long time so a lot of broken exhaust studs. there are a number of ways to do it but i wouldn't let this be your first attempt. old exhaust o n lie take it back to harley
