883 to 1200 engine swap
Old 02-25-2018, 02:18 PM
digvid's Avatar
digvid
digvid is offline
Default 883 to 1200 engine swap
Ok so as the title states, my 2010 sportster Iron 883 ended up with a bad crank. The piston connecting rod has play, I can lift it up about an 1/8 inch and also moves side to side plus the piston scored the cylinder wall pretty deep, so I figured before spending the money on the 883 I'd just swap it out with a 1200.
so that said I found a 2010 1200 with 10k miles for a great deal.
my question is (1) do I need to swap out the main harness or will mine be the same.
And (2) do I need to change out the computer or is the 883 the same?
can you think off any thing else I need to swap?
Old 02-25-2018, 02:54 PM
jbarr1's Avatar
jbarr1
jbarr1 is offline
Should bolt right in. No need to swap anything else. You will need to reprogram the ECM for the 1200, preferably with a tuner like TTS or Powervision.
Old 02-25-2018, 08:42 PM
digvid's Avatar
digvid
digvid is offline
Ok so I have the ecm from the doner bike so I should be able to just swap that out then correct?
Old 02-27-2018, 06:34 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Wink
Your questions can probably be answered by simply checking a parts website, where you can look at part numbers for both 883 and 1200 models.
TestFlyer
05-27-2023 10:46 AM
sgw1064
08-27-2011 08:10 PM
maxhighlife
Exhaust System Topics
11-04-2010 05:16 AM
GhostRider58
03-02-2009 06:20 PM
jaredhd
03-13-2006 12:38 PM
Quick Reply: 883 to 1200 engine swap
