Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Looks good. 2k is a little soft, but no need to lug it anyway. So its probably not an issue. Enjoy!
You'd be surprised at what an extra 10 lb/ft between 2000 and 2500 rpm will do toward getting a heavy bike moving from a standstill. Clutch likes it better, too.
With that said, it looks like a fun ride.
Going to a 110 this summer with about 10.5 comp should help bottom end a little.
