My 110 build on a 2013 RK CVO Need Advice Please
Old 04-16-2018, 09:40 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
Gotcha, I must be half blind. You can't go wrong with an S&S plate.
Old 04-16-2018, 02:24 PM
Campy Roadie
Here's a stock cam plate that looks like every other stock cam plate I've installed or taken out. They all have imperfections in the castings (early TC88s were much better). I'm not trying to one up you to be right OP, but an internet post with a couple pics and no true resolution can cause a case of kennel cough that lasts for YEARS. Guys stumble on a post like this and suddenly everybody has a cracked cam plate. I don't do casting for a living but I'm telling you they ALL look like that (except the aforementioned early TC88s) and I've never had one fail.
This is how Harley Davidson does things, like it or not.
Old 04-16-2018, 03:25 PM
Campy Roadie
Now here's a stock cam plate from a 2002 when Harley was putting out better quality.
Old 04-17-2018, 03:21 AM
kuda427's Avatar
kuda427
kuda427 is offline
I get what your saying,just not the QC I’m used to dealing with
I don’t believe I can install a piece like the ones pictured
I will do a QUALITY piece instead
Piece of mind for me
Thank you for your Input
Campy Roadie (04-17-2018)
Old 04-17-2018, 05:12 AM
Campy Roadie
I understand completely. As I said, you can't go wrong with S&S.
Old 04-17-2018, 05:40 AM
kuda427's Avatar
kuda427
kuda427 is offline
This is the other I have
It’s the 50miles piece
Same cast number but without the a on the end
Attached Thumbnails My 110  build on a 2013 RK CVO Need Advice Please-5b485212-bb25-478c-9da4-f6f622897b0e.jpeg
Old 04-17-2018, 06:44 AM
Fat11Lo's Avatar
Fat11Lo
Fat11Lo is offline
More than a few professional builders, have stated the capabilities of the stock plate/pump, and on my build it would have been more than adequate. However I went with the S&S TC3 only because of the extra scavenging of the 3 stage pump. The other 3 stage pump option is the Thayer (the original) I would have purchased that one but the S&S was part of a package deal. SE and fueling pumps are still 2 stage like the stocker. I see nothing wrong with the ones you have but the most important part is the other side where the pump mounts, is there any wear there?
Old 04-18-2018, 02:58 PM
Dave0176's Avatar
Dave0176
Dave0176 is offline
I replaced mine with an SE plate and pump last year when I did the 103. Didn’t need it just did it because I guess I wanted to spend more money lol. Anyway you got me thinking and I just went down stairs and snapped a few pics of my old plate.
Old 04-22-2018, 06:42 PM
kuda427's Avatar
kuda427
kuda427 is offline
Quick update
Shes almost ready to button up
Hopefully tomorrow after work
I was very pleased to see my crank run out look very good!
Thanks for the help Allen!
Attached Thumbnails My 110  build on a 2013 RK CVO Need Advice Please-e1c93f32-dc35-4923-9031-f8abb5e027ca.jpeg   My 110  build on a 2013 RK CVO Need Advice Please-fdd853b2-6fe8-4a09-829b-62a90cc3f4d7.jpeg   My 110  build on a 2013 RK CVO Need Advice Please-576e208d-8939-46ed-9693-391f7735aff6.jpeg   My 110  build on a 2013 RK CVO Need Advice Please-fc075259-0528-47c9-8ec4-1fa69d137f21.jpeg
Old 04-25-2018, 06:08 AM
Frédéric CM's Avatar
Frédéric CM
Frédéric CM is offline
SnS pump and plate is the way to go
Quick Reply: My 110 build on a 2013 RK CVO Need Advice Please
