Zippers 468 Cam With HD Stage 4 Kit for M8 touring platform
Hey folks. I understand the Zippers 468 to be a bolt in cam. Just wondering if anyone has any experience with this combination. Will be using a 2 into 1 Billet cat and Thundermax tuner.
My understanding is that the 515 cam that comes with the stage 4 kit is pretty soft below 3000 RPMs and looking for a great bolt in replacement that will pull to redline. I’m not a mechanic so any help would be greatly appreciated.
I will be using the existing Harley pushrods.
Thanks.
Thanks.
Thanks.
Thanks.
They work well in a 107" M8, when used with www.technoresearch.com.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
I would worry about in the summer heat and traffic. Not saying there is something wrong with the camshaft at all, it works well in a 107 but going to a 114 stage IV kit @ 11:1 is really to much for it. I've run our TTS 150 (which is a larger design) in the combination your asking about and while it runs like no tomorrow, I do not recommend it as it's not what you should use IMHO. So if you decide to run it be careful is the best I can say to you.
Eccool (05-29-2018)
So, taking into consideration the information provided in this thread, I dedided to go another cam route. I ended up speaking with TR from T-Man Performance and ended up ordering his 226 cam along with a cometic gasket that will help bump the compression to 11:3. I will let you all know how it works out. No Dyno planned at the moment due to going the Thundermax route, but I may have it put on the Dyno up at Americade next month. If so, I will post numbers at that time for anyone who may be interested.
Thanks again to all for your input. Really appreciate it!
Cash007 (05-23-2019)
