New Cams Stock Bike
New Cams Stock Bike
05 E glide that is stock. Me (300lbs) and wife plus gear sit at about 500lbs. Bike is used mostly for touring. It has 34k so I checked the tensioners. You guessed it they are shot.
Since I have to pull the cam plate to do the tensioners and check the bearings I mite as well go for cams.
What would be a close to stock cam that may give me a little bump (climbing hills without shifting as much) but still not have to get tuned or add a bunch more parts. Or will I have to do it any way?
Thanks
Brad
Thanks
Brad
Andrews 21, lots of low end torque. You will not regret it, although you will need to retune
you can use the original push rods if you pull the rocker
recommend you change the inner and outer cam bearings, and throw in a set of S&S lifters while you are in there. Use the Cyco tensioners unless you are doing the hydraulic conversion
have fun!
have fun!
I'd suggest the Andrews 21 as well.
If you want, at a later date, the cam will still work in a 98" Big Bore kit.
Thanks,
Scott
Thanks,
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
