Not sure my pushrods are adjusted correctly...
Installed Cyclerama Cr 570-2's, Hylift Johnson SE lifters and SE tapered pushrods today. As I've adjusted my pushrods I am leary that I did it right. On the jack, I rolled the rear wheel such that the front lifters were "moving" and the rear not. I installed the rear pushrods. Then the same for the fronts. As I adjusted each set I took out the slack, then I could BY HAND adjust nearly 3 turns each. Maybe the last half turn took an easy wrench, but it was so easy to turn the first 2 turns. I soaked the lifters for two nights so I expect they were primed.I am certain I do not have something right. I will research of course, but in the meantime if any has any advice I would much appreciate additional guidance.
RomeoTango (04-26-2018)
Easier yet;
Example;
When the rear exhaust lifter is all the way up............the front exhaust lifter HAS TO BE all the way down.......adjust that one and do not move the engine until it spins freely.
Takes longer, but you'll NEVER have an issue this way.
Repeat on all until completed.
Scott
Example;
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Follow up: I used that video and it was great! I readjusted the lifters per each cylinder at TDC and put three turns on my SE tapered pushrods. Started the bike and it clattered like crazy. I did not ride, but let it idle for a bit and the lifters pumped up - but I still had a tapping noise. I took a length of 5/16 inch tubing (its what I had), put one end to my ear and ran the other end around the push rod tubes, lifter blocks and exhaust flanges to isolate the noise. At the end of my discovery session I realized the rear exhaust was leaking. Let the bike sit overnight and re-torqued that rear exhaust - walla! no more noise. I'll keep an eye on it and I have a tune scheduled for next week. Will ask the tuner how it sounds.
Thanks for the help and responses!
GalvTexGuy (04-26-2018)
