Rough running after engine upgrades.
#51
As in,,,,,the bike runs fine for the first mile or so because it is not up to temp and running on warm up enrichment,,once the enrichment begins to decay and the bike leans out it runs like crap,,,no noises just poor perfromance. Its not a good combo of ac and pipe to start with so it most likely needs more attention to the tune. I just wanted to confirm the mechanicals first because as we all no, no tuning attemps can fix a mechanical issue.
m
m
The following 2 users liked this post by marcodarq:
marcelm (05-09-2018),
Max Headflow (05-07-2018)
#53
#57
Checkings are ongoing, my friend will change some of the upgraded components.
But we have two questions please :
1. if you would have to choose between Andrews TW21 and TW26 camshafts, which one would be the winner ? for a heavy biker. (Bike is HD Softail Heritage TC88B).
2. can we replace the chain cam shaft with gear cam shaft ? we have measured and the cranckshaft has a radial movement of 0,07 mm (about 0.002755897 inch).
Thank you
Thank you
#58
marcelm (08-10-2018)
#59
Hello again, first many thanks for the great support I had here from you. I have posted on a different section, but not many replies, so I come back here.
HD Heritage Softail Classic, Twin Cam 88, 2001, 15.000 miles, with the following mods :
Kuryakyn hypercharger,
Dual Vance & Hines exhausts with buffles,
Cam Plate S&S,
Oil Pump S&S (with 3 rotors),
Lifters S&S Premium,
Push Rod Fuel Moto with 32 threads/inch,
Camshaft TW 21 Andrews heavy biker,
Tuner Twin-Tec (please see foto).
With the Tuner set on Stage 2 Mods, the engine is not running round, so we have changed the settings to "Stage 3" (what is wrote by hand on the right column). With these settings, the engine is running better, but still has some hesitations at about 1800 - 2000.
Which is the best tunner for this model bike ? I would think to an autotune one ...
UrbanRunner
10-02-2018 11:36 AM
marcelm
08-11-2018 05:39 AM
SDHarleyRider
Exhaust System Topics
03-24-2008 11:01 AM
