103 heads and jugs
Thinner gaskets are fine to raise the compression a bit. 0.030" gaskets will bring you up close to 10:1 assuming chamber volumes and piston deck height is optimum. If you do this, you might consider what grade of gasoline you normally have available. One other thing: if you have the matching pistons for the jugs and know which pistons go with which cylinders, I would simply break the glaze on the cylinders, install new rings, and run the existing pistons, assuming they still look good.
And at 10.0, you can use several different cams.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
As long as your cylinders are within tolerance (WITH torque plates) after breaking the glaze, you would probably be ok. I would not buy aftermarket pistons with this in mind without checking to make sure your cylinders mike within tolerance first.
