03 Dyna Randomly dies at highway speed
2003 FXDL Carbureted
Has died 3 times so far:
Dies after riding 15-25minutes @ 50-60mph
1st time - Starter would crank but wouldn't restart until the next day.
2nd time - Same
3rd time - Died while cruising so I popped the clutch/gave it gas and it restarted.
Recently Replaced:
Petcock(non vacuum)
30A breaker
Plugs
Regulator
Wires
Ignition Coil
Crank Position Sensor
Stator(before problem began)
Clutch(before problem began)
Not sure what it could be other than maybe something overheating. I dont want to keep throwing parts at it. Any help is greatly appreciated.
2nd time - Same
Recently Replaced:
Petcock(non vacuum)
30A breaker
Plugs
Regulator
Wires
Ignition Coil
worstdayever (06-16-2018)
Update: havent figured it out. No tip or codes on the odo. Gas tank is clean as far as i can tell. Im going to order a used ignition module and tsm next payday. In the meantime, ill pull the carb and give it a cleaning, maybe the bowl is getting hung up.
On a lighter note, i got my norton up and running after 5 months. Feels good.
Mattbastard (06-21-2018)
