Loss of Power and High Oil Temp
Check for sumping after a ride and carefully remove the pipe plug on the right (brake) side of the crank case. If more than 6 ounces drains out, the motor is sumping. The fix is replacing the o-ring at between the oil pump scavenge spigot and the crank case. Years ago, I started using an additional o-ring behind the scavenge port o-ring to insure a tight fit at the scavenge port. I use the o-ring that goes on the oil pan drain plug for that purpose PN 11105. Also align the oil pump when putting things back together and carefully tighten the pipe plug. Apply some thread sealant and just snug it up; no need to go "gorilla" on it.
LeadDoggy (06-21-2018)
Classic sumping, Ed and djl nailed it.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
BobRR
07-23-2022 02:28 PM
WestTexasRanger
09-24-2012 02:21 PM
