Loose head bolt
Loose head bolt
Was riding the other day, motor suddened sounded extremely “ticky”...sure enough head gasket leak. found that one of the head bolts had come loose, causing it to leak. I tightened back up to spec along with the other one(slightly loose but not too bad)
Wondering if I should open up er up to check the other 2?? Any suggestions?
Like Kirby said, 42 ft/lbs, and if not, then a Full Torque Permanent Thread Insert(s).
Those WILL NOT pull.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Depends on how far you venture from home. See if head gasket leak comes back. Otherwise, sounds like a winter job for the others which are more then likely like the ones you found slightly loose from aluminum and a lot of heat cycles..Not like it's going to leave you setting or leak water in the oil? HAaa..
Like said- they do not loosen up.
studs and bolts stretch over time and lose their clamping value.
You can actually measure it.!
Personally-I would replace them with a better grade.
is it time for a valve job anyway?
cam?
slippery slope......................
I did in mine
cam?
I did in mine
no its not time for any of that, stupid thing gets rebuilt once a year 🤦🏻*♂️ Only got about 8000 km on it this time around 🙄
