Adjustable pushrods locative removal
Old Jun 29, 2018 | 10:52 PM
harwoodj's Avatar
harwoodj
Stage III
Default Adjustable pushrods locative removal
I installed Fuel Moto adjustable pushrods when I did a cam swap about three months ago. I decided not to install new lifters at the time. I noticed increased valve train noise and I have decided to install new lifters. Unfortunaly, I used the Loctite 271 Red threadlocker included with the FM kit. I only used a dot of thread locker on each jam nut. I assume that I will need to use heat to remove without rounding off the nuts. Does anyone have experience using a propane torch to loosen the Loctite? Does anyone know of a better way to remove the pushrods? I am really trying to avoid removing the rocker boxes. That’s why i bought adjustable pushrods to begin with.
Old Jun 29, 2018 | 11:10 PM
chief08's Avatar
chief08
don't assume that try to take them off with out heat if they don't come loose and u don't want to use a torch use a heat gun. I think they will come loose
Old Jun 29, 2018 | 11:11 PM
ROCKOUT Rocker Products
Sponsor
You want to "scissor" the two wrenches. Kinda hard to explain but here goes...
Take 2 QUALITY wrenches of the correct size. Put them on the pushrod... flip one or the other over, or both, until you can hold them close together in one hand. Then SQUEEZE the two wrenches together. Use both hands if needed. This method gives you the most leverage & prevents those nasty wrench slips.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jun 30, 2018 | 07:32 AM
rsking45's Avatar
rsking45
I was a small propane torch and warm up the nuts to loosen up the red locktite,then use 2 wrenches like Rockout suggested
It doesn’t take much to free up the locktite
Old Jun 30, 2018 | 09:33 AM
eaglefan1's Avatar
eaglefan1
QUALITY wrenches can not me overstated here
Old Jun 30, 2018 | 11:07 PM
harwoodj's Avatar
harwoodj
Stage III
Default Thank you all
It seems that I am not the first to run into this issue. Thanks everyone for your advice. I think I’ll try to remove the jam nuts without heat. If they don’t budge I’ll GENTLY apply a bit of heat to the jam nut with a torch. This should be ok, since that’s how the Harley service manual instructs to remove a jammed rear cam bolt. I’ll let this thread know how it goes.
Thanks again!
Old Jul 1, 2018 | 07:42 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Never had to use loctite on adjustables.. if you properly tighten them then you shouldn't have any issues.. all I use are S&S pushrods...
Old Jul 1, 2018 | 08:11 AM
bustert's Avatar
bustert
yep why use lock-tite, thousands of ironheads running around without it, my 1974 with 170+k miles never needed it nor my 2001 sport with rivera adj's.
they do not require much torque either. that is what screws them up, stretched threading.
Old Jul 1, 2018 | 08:39 AM
Robb Liupo's Avatar
Robb Liupo
I'm not sure what model bike you have, but I removed my rocker boxes last night, 15-minute job on a touring model. Remove the gas tank and everything is easy accessible. I also installed adjustable pushrods, I agree they do seem louder, I may just get a set of standard pushrods and slip them in.
Old Jul 1, 2018 | 10:49 AM
Sponsor
I'm not a fan of adjustable pushrods. If you're using a cam that has the same base circle as stock you can get +.030 pushrods from Harley that work fine & set a little deeper into the lifters.
For exact fits, measure the adjustables that you take out & go to Smiths Brothers... https://www.pushrods.net/one-piece-pushrods They are VERY cheap for the quality you get
sabunimwil@gmail.com
Apr 4, 2018 09:06 AM
davessworks
Feb 27, 2010 07:00 PM
Trex
Exhaust System Topics
17
Dec 3, 2009 01:35 PM
insaneblaine
Shovelhead
Jan 12, 2009 06:32 PM
the_ogre25
EVO
11
Aug 14, 2008 03:20 AM
