loss of compression on rear cylinder...
If you have the wants and funds, why not bore to 107? Machine work, new pistons and most importantly, head work is really all you need. The 222 cams should respond well to the compression increase. No need to bore the T/B unless you just want to. Replace the FP3 with the Power Vision, dyno tune and done. See how the exhaust responds to the upgrade; you can always change pipes.
thanks
Glad you found the problem. When you button her back up, add a External Breather System to your A/C, or get and A/C that already has an EBS, that way you won't get all the performance robbing hot, oily, oxygen depleted air into your combustion chambers, which is also causing that carbon build-up you saw.
LINK to info on EBS's.
LINK to Performance A/C's.
Feel free to come down and visit us...we're just down the 78 from you.
what EBS do you suggest for my AN big sucker.
thanks
Received 3,931 Likes
are you tightening them good? have had several bikes with screw adjustable rocker arms, never had one of those come loose. curious how many TPI on your adjustables?, I have the S&S quickees are 32tpi, the finer threads the torque compounds more, have not had any come loose, checked them recently are good and tight.
I would not get all panicked about a pushrod getting lose, Or tight.
I would check the technique how the jam nut is snorked.
Use the one-handed squeeze method if you can (both wrenches in the palm squeezing them together
will truly tighten the lock nut dwn.)
In more years then you want to know I have not see this to be a problem. (coming lose)
Dont wory about it.
a non adj pushrod one is ideal, but a PIA for other work on the bike.
Dont wory about it.
was traveling on the highway running ~70 when the bike started slowing then just shut completely off so i coasted to the side of the road and start to restart her. bike was cranking but not firing. had just filled up not even a mile away. bike was getting fuel so i pulled the plugs to check them out as i just replaced them about 1k miles ago. reinstalled then and tried to restart. bike started but was only a sputter for a brief moment then it shut off. it would not restart. while cranking there was an odd sound from the rear cylinder as it didnt sound like the front. pulled the plugs and put my thumb over the front cylinder spark plug hole while cranking and the compression almost blew my thumb off. tried the same with the rear and i barely felt and pressure. i was about 200 miles from home and was with a few other riders and a truck with a trailer so I trailered the bike home. just pulled both cylinders but do not see what the issue is. I was going to go 107 kit this winter so looks like I will do this now. however, I have no idea what went wrong and would like to know before I put it back together. cylinders look great...pistons have carbon buildup but I don't think that would cause a loss of compression. could there be a hole in the piston under the carbon. what are some of the reasons for loss of cylinder compression.
bike is 2012 flhx with 18k.
any ideas what I should be looking for at this stage.
thanks
thanks
I ran into the exact same issue with my 2018 CVO limited. I towed it to HD service and after a few days of investigation, service told me that my rear cylinder is low on compression and they are going to tear down the engine to find out why? I was wondering what things might cause this? mainly worried with the cost of repair and parts.
Hey,
Suggest you start another thread on you subject with as much information as you can provide about the bike.
Olsen185
Engine Mechanical Topics
29
01-16-2017 06:56 PM
