Lifters Brand vs stock HD?
I'm swapping out my 03 SE Road King 103 stock cam plate for a SE hydraulic cam plate & will be posting a link to the video in the near future. The motor is 16 years old so I'm changing out the lifters also among other things.
Q: stock lifters in motor are 18538-99c stock lifters. They've lasted this long & none are collapsed so they're pretty good at $125 or so. Q2: I want to swap them out but for what? The needle bearings in the rollers are what I'm wanting to make sure are the larger SE type for more oil & are more heavy duty. Fueling 4000 ($135) are great from what I've heard and are 1/2 the price of SE lifters #1857-13 ($250). Tons of other manufacturers lifters out there (V&H, S&S etc). So, If there's an HD tech (or someone who has actually gone through their own selection process) out there that would like to comment on the Whats what, I would really appreciate it. Me = Fixed income, don't want to waste $$. Thanks much! Bob
YIKES! She's about to BLOW!
If you are limited in funds, there’s no need to spend money for the SE cam plate. Just replace the worn shoes with Cyco shoes.
Hard to beat S&S standard lifters as replacements. Good idea to change inner cam bearings to the full compliment type while you’re in there.
That should cover you for many miles!
Biker Bob (08-07-2018)
I use lifters from WFOLarry, he's a member here. He has Johnson lifters in all price ranges, anything he has is better than anything HD can sell you.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
I'll more than likely go with the S&S lifters although Larry's w/pin oiling look PRETTY GOOD! When I set the S&S adjustable rods set that have 32 tpi. I like to start at slight touch then count until bottom out & back it off roughly half the nut flats. I do it on the first intake & exhaust and then set the 2nd jug to duplicate. S&S lifters (33-5350) are looking like the winner so far because of the higher oil flow (80cc). I found them for 135 - 10% & FS at Denis Kirk. Probably will use the stock push rods since I'm not changing the cam. THANKS to all for the posts!
If you are on a budget take a look at these...these are the same as teh Chevy lifters people always talk about. I used them in my bike
https://www.vthunder.com/lifters/hy-...c-lifters.html
Biker Bob (08-08-2018)
