Built 98ci wont make power past 5300rpm
Looking for a starting point to troubleshoot.
I built a 98ci motor a few months ago
- 98ci cp forged pistons 10.75cr
-heavily ported heads with larger valves and beehive springs
-44mm cv carb
-.610 cams
-feuling camplate, oil pump, lifters with hydraulic tensioner
-thrashin supply 2-1 exhaust
-twin tec ignition
After I built the motor I took it to get dyno tuned. Motor made decent numbers of 97hp/112tq.
I know the attached dyno sheet is running rich, but changing out the jets to leaner mixture resulted in similar numbers.
Where should I look to find out why the bike falls flat at 5300? The shop that did my heads and sold me the cams said they make power well past 6k rpm. I thought the 44mm cv would be enough for the 98ci, am I wrong? My initial thoughts are to look at carb and exhaust to try and move more air through the motor.
that's the pipe. 1 3/4in head pipes. Collects in front of camchest, sealed baffle endcap. Basically a stainless bassani road rage 2.
cam is a custom cam from DC V twin in Perry GA. 610 lift is the only spec I can remember at the moment. Just researched sumping. I hope it's not the case, but I'll check this evening
https://www.thrashinsupply.com/collections/exhaust
Not a bad lookin' set of tubes. I'm LOLing the "NOT FOR USE IN CA..." when they're made in Los Angeles. Holy $hit pricing tho. Which baffles did you go with?
Who ported the heads too? "Heavily ported" by your good buddy who owns a Dremel?
That CV44, assuming it's set up properly, is good well north of 100hp.
Won't hurt to check for sumping but with peak TQ at 112 I doubt that sumping is the problem but it won't hurt to check. I run the CV44 on an all bore 107" motor that makes 124TQ so the CV44, jetted properly is enough carburetor. Did you get a flow sheet on the heads? Heads and/or exhaust is where I would be looking. Don't know anything about the cams so can't comment on them.
heads were done by same shop that designed the cam. Heads and cam were designed to go with each other. Shop is DC V-twin out of Perry ga. Same cam and heads on another 98ci build, with same pistons made 118hp/118tq. Bike had a mikuni 45 and fat cat exhaust, which is the only difference from mine. It made peak power around 6100rpm.
my concern is that my bike stops making power early in the rev range
