Routing clutch cable behind downtubes
09 FLHTCU. Putting new bars on and new braided/shielded clutch cable. I am also adding an Arlen frame grill to the front downtubes. I currently routed the new cable behind the downtubes giving the front a more clean aesthetic. It is a bit close to the cylinder now, especially the rubber cover over the adjustment turnbuckles.
Does anyone run clutch cables behind the downtubes or will this end as I imagine...a melted rubber cover mess? It's about 1/2" at the top gaining more gap as it heads down.
Northern Glide
03-03-2013 12:17 PM
